hi i am in need of some help with my jetting im wondering if my jetting is anywhere near correct...i have fmf pipes, t.o.r.s eliminated, and k@n pods...my mains are 340's and my pilot is 25's also what clip should my needle's be on also do you read the dipstick for the gear oil threaded in or resting on the threads thanks
you need to give more info.
where you are ? elev. ? temp. ?
any porting ?
check gear oil with dipstick threaded in.
i am in west michigan as far as i know there isnt any porting it is about 25-32 degrees here as far as elevation i think im at sea level no more than 500ft above thanks
what you have right now sounds good. but i would go up around 10 or 20 more on your main jets and then put your needle on the 3rd clip...
