kevl Posted January 17, 2008 Author Report Posted January 17, 2008 Did you double check your carb slides like I mentioned above? It's sounding more and more like what I had dealt with... my buddy is doing the carb work this weekend. are two stroke carbs pretty much the same as four stroke when it comes to tear down and cleaning. i see a little eye on the carb and when i hit the throttle i can see the level move is that what you mean by being synch Quote
NitroTate Posted January 17, 2008 Report Posted January 17, 2008 my buddy is doing the carb work this weekend. are two stroke carbs pretty much the same as four stroke when it comes to tear down and cleaning. i see a little eye on the carb and when i hit the throttle i can see the level move is that what you mean by being synch I think they are pretty close to the same yeah. They are really easy. Yes you're looking at the right spot, and I know you said you see the level moving but do you see the "mark". there is a "ping" mark that kind of looks like if you were to start drilling in a peice of metal and then quit before you went through so kind of a divet. This little ping mark should only be visible at a certain point like half throttle or so (I forget exactly) the little ping mark should pass by the window in both carbs at the same time to be "in sync". Make sense? Quote
kevl Posted January 17, 2008 Author Report Posted January 17, 2008 I think they are pretty close to the same yeah. They are really easy. Yes you're looking at the right spot, and I know you said you see the level moving but do you see the "mark". there is a "ping" mark that kind of looks like if you were to start drilling in a peice of metal and then quit before you went through so kind of a divet. This little ping mark should only be visible at a certain point like half throttle or so (I forget exactly) the little ping mark should pass by the window in both carbs at the same time to be "in sync". Make sense? thanks it make sense. my brother is coming by tomorrow and ill have him check one side and ill check the other.thanks and ill let you know. if they are, will tearing the carbs apart to clean them screw it all up. Quote
NitroTate Posted January 17, 2008 Report Posted January 17, 2008 thanks it make sense. my brother is coming by tomorrow and ill have him check one side and ill check the other.thanks and ill let you know. if they are, will tearing the carbs apart to clean them screw it all up. No, not at all just make sure you reinstall them in the correct sides and be careful not to bend your needles. You don't need two people to sync them though, the windows are both viewable from one side of the banshee. You can just kneel down and look at both carbs at once and watch the windows as you push the throttle and those two little marks should show up in the windows. Quote
kevl Posted January 18, 2008 Author Report Posted January 18, 2008 No, not at all just make sure you reinstall them in the correct sides and be careful not to bend your needles. You don't need two people to sync them though, the windows are both viewable from one side of the banshee. You can just kneel down and look at both carbs at once and watch the windows as you push the throttle and those two little marks should show up in the windows. alright, i didnt notice both windows i just figured theyed both be on the outside. ill check thanks. Quote
kevl Posted January 19, 2008 Author Report Posted January 19, 2008 (edited) i got the carbs cleaned today and put back together. found out it just dont like the cold. i ran the banshee for a while and one pipe got warmed up about 5 min before the other. both cylenders are fireing. plus i think i flooded the shit out of them and when i got it started again it rev real high (real high) and we took the key out hit the kill switch pulled the plug wire and the tether cord and wouldnt shut down we tapped the gas and it rev down and stopped. my ? is the slides in top of the carb are dry should they be lubed with something. Edited January 19, 2008 by kevl Quote
kevl Posted January 20, 2008 Author Report Posted January 20, 2008 i got the carbs cleaned today and put back together. found out it just dont like the cold. i ran the banshee for a while and one pipe got warmed up about 5 min before the other. both cylenders are fireing. plus i think i flooded the shit out of them and when i got it started again it rev real high (real high) and we took the key out hit the kill switch pulled the plug wire and the tether cord and wouldnt shut down we tapped the gas and it rev down and stopped. my ? is the slides in top of the carb are dry should they be lubed with something. anyone have ideas thanks Quote
