i just had my bike jetted at a local shop. i took it out and it was running ok but alil rich down low, bogging a bit. i had it out for a little while and it was fine but after a few hours it started running funny. it seemed like the left cylinder wasnt firing. i took it home and replaced the plugs but the same problem is still there. the bike starts right up, idles a lil rough. i felt the pipes and the left side doesnt seem to be firing b/c the pipe isnt wrming up like the right does. if i rev it up to about half throttle the pipe begins to warm and i can feel it coming out the silencer. im going to take it back to the shop but was wondering what was causing this?
the spark is good swapped cables and still a problem on that side. it idles but a lil rough. it stalls after running about a min. or so. both plugs are a nice brownish color. will doing a plug chop help? also both carbs and all parts were cleaned in an ultrasonic cleaner before being jetted. mods are pipes k&n thats it. the bike is running ok not missing or anything
Edited by BIGSHO
Have you checked the reeds? If they are worn or damaged they can cause similar issues, and you mainly notice it at idle. Just a thought
