probably not, most spark issues will cause running problems. I would be inclined to check the choke crossover tube, pilot jets, air screws first. Then probably engine compression. You get down around 100 psi and they will run, but will be hard to start.
yep my banshee was hard to start warm and it turned out to be low compression. about 60-70psi and it still ran :woot:
ive checked my compression at cold, wot, 12 kicks 110 psi both cylinders. im not sure how many times im sposed to kick it over ? i know for a car its like 3 turns so ... my plugs are the usual brownish color, havent rechecked jetting yet. i also checked the fire and it seems a bit weak..
Edited by dirtdemon
