krauss4 Posted January 5, 2008 Report Posted January 5, 2008 i just got some 35 mm carbs and i need intakes. i see that some intakes have a built in crossover tube and some come with a place to have a boost bottle. and then there are some that have no way of haveing a crossover tube or bottle. what do i want? this is pretty much a drag bike. Quote
WALLACE84 Posted January 5, 2008 Report Posted January 5, 2008 You want split intakes. The ones with the boost bottle are pointless and they are just in the way Quote
krauss4 Posted January 5, 2008 Author Report Posted January 5, 2008 what about the ones with a built in crossover tube. the factory intake has a crossover tube. does it do n e thing or do you really not need it? also do i need to sync. the carbs after they are on? Quote
BigRed350x Posted January 5, 2008 Report Posted January 5, 2008 what about the ones with a built in crossover tube. the factory intake has a crossover tube. does it do n e thing or do you really not need it? also do i need to sync. the carbs after they are on? Yes, you will definitely need to sync the carbs after they are on. Its a little bit harder to tune with split intakes depending on what your carbs and engine setup are. I've had both, built-in crossover and split, and haven't noticed much of a difference between the two either way. Quote
WALLACE84 Posted January 5, 2008 Report Posted January 5, 2008 Its a little bit harder to tune with split intakes depending on what your carbs and engine setup are. I've had both, built-in crossover and split, and haven't noticed much of a difference between the two either way. What im saying is they are just a pain in the ass with the intakes the have the boost bottle. They get in the way of fuel lines,etc and when I ran them, the bottle kept coming out of the rubber gourmets. You dont need a boost bottle for anything so it is just extra crap to screw with. Intakes with built in crossovers are fine btw Quote
