05 won't start.....cleaned carbs now no fuel going to jugs,could it be vapor locked? there is gas going to carbs and there is good spark. ran fine before cleaning carbs. wtf!
Make sure the tube that connects the carbs is connected. simple but I always forgot
Yeah, like he said, make sure the choke tube is there. You might want to check the slides and bowls on the carbs. If they are stock, the bowls are unique and cannot be swapped side to side, the slides MUST have the cutaway part pointing towards the air filters. Also, make sure your slides arent set too low, raise the idle a little, and try kicking again. Good luck bro!!
thanks for the help.....forgot to hook up choke tube....simple things are always overlooked. :biggrin:
