cudon Posted January 4, 2008 Report Posted January 4, 2008 05 won't start.....cleaned carbs now no fuel going to jugs,could it be vapor locked? there is gas going to carbs and there is good spark. ran fine before cleaning carbs. wtf! Quote
onebanshee Posted January 4, 2008 Report Posted January 4, 2008 05 won't start.....cleaned carbs now no fuel going to jugs,could it be vapor locked? there is gas going to carbs and there is good spark. ran fine before cleaning carbs. wtf! Make sure the tube that connects the carbs is connected. simple but I always forgot Quote
LiftdT4R Posted January 4, 2008 Report Posted January 4, 2008 Yeah, like he said, make sure the choke tube is there. You might want to check the slides and bowls on the carbs. If they are stock, the bowls are unique and cannot be swapped side to side, the slides MUST have the cutaway part pointing towards the air filters. Also, make sure your slides arent set too low, raise the idle a little, and try kicking again. Good luck bro!! Quote
cudon Posted January 5, 2008 Author Report Posted January 5, 2008 Yeah, like he said, make sure the choke tube is there. You might want to check the slides and bowls on the carbs. If they are stock, the bowls are unique and cannot be swapped side to side, the slides MUST have the cutaway part pointing towards the air filters. Also, make sure your slides arent set too low, raise the idle a little, and try kicking again. Good luck bro!! thanks for the help.....forgot to hook up choke tube....simple things are always overlooked. :biggrin: Quote
cudon Posted January 5, 2008 Author Report Posted January 5, 2008 Make sure the tube that connects the carbs is connected. simple but I always forgot thanks for the help....overlooked choke tube Quote
