Just got my new +6 swingarm from jeremy(Lethaface).I need help removing the pivot bolt I think its called.Its the really long one toward the front of the swinger.I hit it with a hammer a bit and no movement???What do I do?Its my first time removing my swingarm btw.
on my zilla i just threated the nut on it and put a socket it then beat the piss out of it ...
I put my banshee towel over it and hit it with the hammer and no movement.Do I just keep hitting it till it comes off?
Edited by 06BaNsHeE
Do you habe the bike off the ground? Not sure if you took the axle apart first or were taking it all off together, ive done both... anyway, i usualy take an air hammer and hut the bolt with it to start it if its stuck, never had one that wouldnt come out after that.
Axle is still on.I havent touched anything except that.You think If I lift it and just put a towel over and just hammer it out it will come off?Or do I start by taking of the shock.Its a stock carrier swingarm so I didnt want to take apart the axle
take the shock off and get the tires off the ground, may be binding some.
Thanks Ill try that tommorow morning.Its like 40 degreez here in Miami And to cold to work on the banshee.Ill post back tommorow.
what?!?!! 40 degrees? Thats like summer time!
lol... you need to come visit. Its 10 outside right now, a foot of snow on the ground and 40mph wind. It pretty damn cold here, if it was 40 id be in a t-shirt.
