sheerider1026 Posted January 2, 2008 Report Posted January 2, 2008 i ordered a dek and a eek needle.. i have a dej in it now.. which should i try first the eek or dek?? which do u guys have better luck with?? i know that snop is good on these setups.. maybe he will chime in.. Quote
Snopczynski Posted January 2, 2008 Report Posted January 2, 2008 start with an eek and adjust accordingly. Keihin Needle Chart Quote
sheerider1026 Posted January 2, 2008 Author Report Posted January 2, 2008 as weird as it may sound i am running a 155 main with the dej needle and it seems a little rich.. after i put my home ported jugss on it it runs even better.. maybe the numbers will all change when i change needls.. i will up the jet when i swap the needle out to be safe.. kinda start over on tuning it.. it has a sluggish 1/4 throttle right now.. i am thinking it is a little rich.. what do u think? Quote
Snopczynski Posted January 2, 2008 Report Posted January 2, 2008 you need to figure out if its a sluggish rich burble, or a lean hesitation. Refer to the chart and change needles accordingly. Quote
theeechozen1 Posted January 2, 2008 Report Posted January 2, 2008 my bike seemed to like the EEK the best...but this was with a 38mm carb Quote
sheerider1026 Posted January 3, 2008 Author Report Posted January 3, 2008 hey guys i put the eek needle in on the 3rd clip, 48 pilot 1.5 turns on airscrew and a 165 main.. man what a difference. it starts on the first kick now with no choke.. it also rips hard with no hesitation.. props to snopz.. appreciate the help on the jetting.. it use to be hard to start, had hesitation, and the throttle was not crisp either.. i love the 2 into 1 now.. not gonna look back.. anybody wanna buy some stockers? lol kiddin.. Quote
Snopczynski Posted January 3, 2008 Report Posted January 3, 2008 move the clip around and see if it gets better. Also try the eej needle. Quote
sheerider1026 Posted January 3, 2008 Author Report Posted January 3, 2008 which way on the needle?? all i have is a dek.. i can't imagine it running any better.. i am on the third clip down from the top of the needle.. when i put the eek in(from the dej) it was night and day difference.. its a rocket.. i can't see why anyone would not like the 2 in 1 setup.. easy to rejet, more room, no syncing either.. its perfect for me.. do you still run one? Quote
Snopczynski Posted January 3, 2008 Report Posted January 3, 2008 which way on the needle?? all i have is a dek.. i can't imagine it running any better.. i am on the third clip down from the top of the needle.. when i put the eek in(from the dej) it was night and day difference.. its a rocket.. i can't see why anyone would not like the 2 in 1 setup.. easy to rejet, more room, no syncing either.. its perfect for me.. do you still run one? Yeah I run one. I actually ride with 6 banshees that run them. Just try some other needle positions on the eek. I think I am running an EEJ, cant remember which clip position. Quote
sredish Posted January 4, 2008 Report Posted January 4, 2008 2 in 1 is a killer setup but it has to be tuned properly, more than just with a jet change. the 2-1 is very finicky with the needle but once set, BOOM, it's a killer ride. EEK is a good standard for the 2-1. Quote
sheerider1026 Posted January 4, 2008 Author Report Posted January 4, 2008 yea i was amazed on how well this bike ran after changing the needle and doing some adjusting .. i was always told by a friend that the 2 into 1 was very sensitive and would need to be rejetted constantly, not so true.. i just think he meant it can be a pain in the ass to tune.. maybe he seen someone fighting with one.. most people don't think to change the needle, they seem to focus on the main jet and thats it.. i do however have mine running perfect, now its time to get my topend bored, (its low on psi's) Quote
chevrolet banshee Posted January 4, 2008 Report Posted January 4, 2008 Well hear i am feeling retarded, I thought i knew a lot about carbs but i guess not. What is the deference between all the different needles? makes me wonder whats in my shee's carbs. How can you tell what needle you have? thanks chevshee Quote
sheerider1026 Posted January 4, 2008 Author Report Posted January 4, 2008 when u take the needles out it will be stamped on the needle.. will say cgl, eek, dek, dej, something like that.. its up close to the blunt end of the needles.. check it out.. Quote
chevrolet banshee Posted January 5, 2008 Report Posted January 5, 2008 (edited) when u take the needles out it will be stamped on the needle.. will say cgl, eek, dek, dej, something like that.. its up close to the blunt end of the needles.. check it out.. I think i will go check that out. What needles are the best? chevshee Edited January 5, 2008 by chevrolet banshee Quote
