tyguy Posted December 28, 2007 Report Posted December 28, 2007 i have stock steels and the end where its small like a nipple, is burnt a little bit, im getting the 1000 fibers and i was wondering if i should use these steels or not, thanks Quote
shanYE west Posted December 28, 2007 Report Posted December 28, 2007 I got some blued steels in my pack.. Its ok as long as they're not warped. If your getting new fibers might as well get some new steels too. Quote
jbooker82 Posted December 28, 2007 Report Posted December 28, 2007 You can sand blast the steels to bring them back to life. Quote
tyguy Posted December 28, 2007 Author Report Posted December 28, 2007 thanks guys, ill try the sandblasting sence i have one, thanks for the inputs. Quote
csrmel Posted December 29, 2007 Report Posted December 29, 2007 you can check the steels by using a micrometer to check for high and low spots. but a micrometer wont work for checking warping or a wobbly friction disc. for that you would need to set each steel on a plate of thick glass, preferably half inch or thicker, or a really smooth flat piece of granite. then try and slide a piece of paper under different sides of the friction disc. you shouldn't be able to slide it under any part of the steel friction disc. if you can, then chances are its warped. if you check all the discs and they turn out ok, then put a piece of 500 grit sand paper on the plate of glass or granite and rub each disc light amount of pressure to gently roughen up the steel friction disc. you don't want large scratches or gouges. just a dull finish to the steel friction discs. this would greatly aide in gripping the clutch discs when you let out the clutch to take off or shift gears. the friction discs are cheap enough that you can just buy new ones if the current ones turn out to be bad after testing them. . or get a whole clutch kit from tisk for $45 that comes with new steels and clutch discs and heavy duty springs and call it a day. whew. Quote
sheerider1026 Posted December 29, 2007 Report Posted December 29, 2007 what are these 1000 fibers that you speak of?? that from a crotch rocket or something?? and if so why do you use them?? advantages?? Quote
jbooker82 Posted December 29, 2007 Report Posted December 29, 2007 Yea dont blast the crap out of them. Start the air pressure out low so you dont leave them real rough. Quote
tyguy Posted December 29, 2007 Author Report Posted December 29, 2007 well thanks csrmel, that was very helpful and well spoken, they didnt turn to be warped just aliitle burnt on the edges, thanks for the info, the 1000 fibers are from a rocket, do a search and youll find out about them, Bansh-eman knows all about them and swears by them, look onto one of his posts youll find more info there, sorry. thanks guys for the info, much appreciated. Quote
shanYE west Posted December 29, 2007 Report Posted December 29, 2007 what are these 1000 fibers that you speak of?? that from a crotch rocket or something?? and if so why do you use them?? advantages?? They're from a FZR1000 street bike. They're more beefy then the stock fibers with more surface area. Quote
sheerider1026 Posted December 29, 2007 Report Posted December 29, 2007 They're from a FZR1000 street bike. They're more beefy then the stock fibers with more surface area. wheres the best place to getem?? are they a drop in part or do i need to do any mods to makem fit? Quote
