This motor is from a 93 banshee. It has a complete wiseco top end rebuild with less than 5 hours of ride time on it. The only oil ever used in this motor is klotz benol mixed 32:1 I would like to get $1300 for it. Below is a list of mods that were used with this motor.
Engine:
Klotz Benol 4oz per gallon of gas
Pro Honda 10w30 oil in clutch and tranny changed regularly
Carbs jetted with 270 main and 27.5 pilot jets and higher flowing needles
Boysen reeds
Cross over tube ports on intake manifolds have been plugged
Pro Design pro flow dual stage foam air filter with Klotz foam filter oil
Stock airbox lid modified for higher flow
FMF Fatty pipes and power core II silencers
O-ring pipe to silencer connecters
Barnett heavy-duty clutch springs
Barnett clutch plates 10% wear left
Wiseco 64.75mm prolite pistons and complete top end kit
Trued and welded Crankshaft
Adjustable +10 to -10 degree ignition timing plate set at + 4 degrees
not to be rude, but I have bought motors in $1000 range that had a lot more to offer and were in a lot better shape. If you have your heart sent on a $1000, maybe you should take the time and clean the parts up and part it out.
