my bike has pipes, jetted, k&n tors removed, no mods recently. the throttle stuck while i was riding today. i pushed in the throttle and it got really hard to press. i let off it and it was stuck so i just tapped it a few times to see if it was hung up and it stayed stuck wide open. got the bike home and checked the cable going in on top of the carbs, pulled both out of the boot but the didnt seem to be hung up. the thumb thottle also movses freely now. also it is just the right side stuck cause only one cylinder is revving up when i start it. any other suggestions? thanks
Edited by BIGSHO
make sure theres not a lot of play in the thumb lever that would casue it to hit inside the housing of the thumb throttle , i had one hang up there and i had to bend the lever in side where the cable goes through up so it would hang up. look over the cable also , theres a hang up somewhere
see the mark in the housing
there could definitely be sand in the slide, but there is no hang up ath the lever or on top of the carbs. both have play that why i dont get it.
in the pic above it would only hang up every so often , and then show no signs of hanging
or it could be sand
only one cylinder is running wide open though. that wouldnt cause a malfuntion at the lever then both would be firing wot right???
i didnt read about the one cylinder part , id say its in your cable at the 2into 1 part where both cables run into the one pull , they can mess up there
