can the throttle effect the idle cause on my banshee the throttle seems loose i got thumb throttle u can wiggle it but when u push down it gets tight like normal im askin because i tried every thing to get thid shit to idle and i got as far as it idlilng with the choke but with out the choke it doesnt but if i
hold the throttle to the point were it sounds like it hits a button it holds and idle idk whats wrong :mad:
What are your mods, current jetting, temps and elevation.
It should idle without giving it any throttle.
Do you still have the tors on?
mods are fmf pipes dg silencers proflow filter boost bottle and the guy i got it from said it was big bore
and the tors are disconected but it is still on my carb tops it idles but with choke only close the choke and it cuts off
but the throttle got a little loose ness to it -- its like to clicks u can press it in to a point and then push it again to rev it
i also looked in the clymers and it said throttle should have free play of 4-6 mm and mine has about 1in of free play
