Guest cheetabanshee11 Posted December 4, 2007 Report Posted December 4, 2007 Ok guys i am putting this on here for a buddie of mine here is what he has: Tyson Ported 10 mil Cub with Pistsons 68mm bore Stock Cut Head 10 mil Forged Crank V Force 2 Reeds UPP intakes 39 pwk carbs for fuel pump 1-5 OverRide Tranny RDZ 2 Out Left Side with stingers Bare he just wants 2200 for all this the motor has only about 3 min of run time and yeah i mean 3 min that is on the crank and whole top end the pipes has about 10-15 passes on them.... Quote
badassbanshee479 Posted December 4, 2007 Report Posted December 4, 2007 how much for just the crank pistons cylinders and head? Quote
Stellar Performance Posted December 4, 2007 Report Posted December 4, 2007 Ok guys i am putting this on here for a buddie of mine here is what he has: Tyson Ported 10 mil Cub with Pistsons 68mm bore Stock Cut Head 10 mil Forged Crank V Force 2 Reeds UPP intakes 39 pwk carbs for fuel pump 1-5 OverRide Tranny RDZ 2 Out Left Side with stingers Bare he just wants 2200 for all this the motor has only about 3 min of run time and yeah i mean 3 min that is on the crank and whole top end the pipes has about 10-15 passes on them.... Is this a complete assembled motor? If so, that is a sick price for everything. Quote
Guest cheetabanshee11 Posted December 4, 2007 Report Posted December 4, 2007 no its not completely assembled it dont have cases or the clutch set up or flywheel and stator but has everything else... ill check on the crank and top end i would say around 1500 for it ..... Quote
Guest cheetabanshee11 Posted December 4, 2007 Report Posted December 4, 2007 and seriously this motor has like 3 min on it we put it on the frame that he had bought and it needed a bracket made for the pipes so i held the pipes on by hand and he started it and ran it just long enough for the pipes to start getting hot where i couldnt hold them... Quote
Guest cheetabanshee11 Posted December 5, 2007 Report Posted December 5, 2007 2000 plus shipping for everything Quote
