Sunny Illmoon Posted December 2, 2007 Report Posted December 2, 2007 HI all, newbie checkin in. , i have never thought to look at my sprokets until i went racing with some friends on the pavement for bragging rights, well as a race would start we take off and of course i am off first because of the newly discoverd big ass gear in the back, kick in to fifth and the fun is still on but my buddie is starting to reel me in like a tired fish, By sixth its obvious he is havin way more fun just before i run flat. Big carbs, reed cages, and cpi inframes are all i can on his bike but know theres more inside because that mother is runnin on the big end, if you ask these guys they say stock(other words top secret shit"whatever" My ? is is there a happy medium with the rear sproket for me down from the 45t, i ride mostly trails, fields,and some occasional brooksville sugar sand. In the sugar sand i have no problem sitting with the old girl pinned even up a slight incline but first through third suck or fling actually. I believe there is improvement to be made on all surfaces by getting away from the 45 but dont think i need to go 41 there is a magic number out there somewere mabey its a 42.5t(kidding) just want to put sixth gear off a little. Will droping down make her a little linear through-out the powerband? Thanks,Gurus Quote
badassbanshee479 Posted December 2, 2007 Report Posted December 2, 2007 what all is done to your bike? and what front sprocket are you running? Quote
Sunny Illmoon Posted December 2, 2007 Author Report Posted December 2, 2007 what all is done to your bike? and what front sprocket are you running? .08 over t-5s stock carbs-340 main 27.5 pilots t-5 intake stock reed cages fmf tourque reeds dyna-fs ignition intake and exhaust ports-mild clean up cool head 22cc domes-93 oct 14-45 sprokets 20" rears 32:1 R lube oversized radiator oversized ballz Thanx Quote
badassbanshee479 Posted December 2, 2007 Report Posted December 2, 2007 (edited) I think I would bump the front up to a 15 tooth and leave the rear. Just remember, up in the front more top end, down in the front more acceleration, less top end In the rear, down in the rear more top end, and up in the rear, more acceleration. Also, adding 1 tooth to the front sprocket is like removing three from the rear, and vise versa Edited December 2, 2007 by badassbanshee479 Quote
Sunny Illmoon Posted December 2, 2007 Author Report Posted December 2, 2007 I think I would bump the front up to a 15 tooth and leave the rear. Just remember, up in the front more top end, down in the front more acceleration, less top end In the rear, down in the rear more top end, and up in the rear, more acceleration. Also, adding 1 tooth to the front sprocket is like removing three from the rear, and vise versa I thought about your reply for a while, and it seems that the 15t will put me right between stock and what i am currently running...ask and you shall recieve around here badass Will let you know how it reacts by next weekend. Quote
