flattrakker Posted November 29, 2007 Report Posted November 29, 2007 im lean on my pilot jet.. but for now i want to get it started and running and not so worried about bogg off idle.. im having a hard time getting her started cuz shes lean.. how should i go about starting it? like.. full choke little gas.. hlaf choke no gas.. no choke full gas.. i think you get what i mean.. also i need part numbers for aftermarket pilots jets.. Quote
RIPRuck Posted November 29, 2007 Report Posted November 29, 2007 im lean on my pilot jet.. but for now i want to get it started and running and not so worried about bogg off idle.. im having a hard time getting her started cuz shes lean.. how should i go about starting it? like.. full choke little gas.. hlaf choke no gas.. no choke full gas.. i think you get what i mean.. also i need part numbers for aftermarket pilots jets.. How do you know your lean? What size are you running now? Quote
flattrakker Posted November 29, 2007 Author Report Posted November 29, 2007 stock pilot with lrd pipes and kandn pods Quote
RIPRuck Posted November 29, 2007 Report Posted November 29, 2007 Are your floats adjusted correctly? It should still start with the 25 pilots in there. Does it start fine with the choke pulled out? Quote
flattrakker Posted November 29, 2007 Author Report Posted November 29, 2007 nope... how do i adjust the floats? Quote
fixitrod Posted November 30, 2007 Report Posted November 30, 2007 nope... how do i adjust the floats? Did start okay when it was warmer out? Have you done anything to the carbs? Does it start if you hold the throttle wide open as opposed to at idle or just above. You could adjust your pilot screw in to richen a bit. Try it at 1/4 turn from seated. 1/2... 3/4 ... if it starts they are lean. If you get over two turns out and it starts they are rich. Cold weather does create a lean condition. The screw adjust the amount of air that comes in. If it won't start at all it may not be jets at all. Make sure the choke tube is between the carbs too... start simple. Quote
flattrakker Posted November 30, 2007 Author Report Posted November 30, 2007 (edited) are you saying adjust the pilot or adjust the airscrew? i put 350 mains in it after i added pipes and filters. Edited November 30, 2007 by flattrakker Quote
2ss Posted December 2, 2007 Report Posted December 2, 2007 where did you get 350 mains at I cant find any over 330 thanks Quote
rtcc Posted December 2, 2007 Report Posted December 2, 2007 where did you get 350 mains at I cant find any over 330 thanks jetsrus.com they rule. Quote
