ny98banshee350 Posted November 18, 2007 Report Posted November 18, 2007 yea i know its goin to alot of $ but..... wut do u want for the frame & swingarm?? if u can find out wut the shipping is to area code 11779 Quote
f4istunna Posted November 19, 2007 Author Report Posted November 19, 2007 (edited) Full set yellow/red plastics- decent shape uncut normal wear gas tank- good shape w/ petcock crank- good bearings and rods radiator- good shape few fins pushed over no leaks comes w/ hoses Moose gasket set- New in box stock silencers- baffles out good shape stock mid pipes w/ sheids-good stock header pipes- some surface rust, good shape stock bore cylinders-good shape no gouges or out of ordinary wear stock carbs -good shape Stock bore pistons - Namura New in box stock head- good shape boost bottle -good throttle cables - new never used throttle cables-used w/ peices that go in top of carb (tors??) footpegs- ok shape still decently sharp headlights-one mint one has small break in lens at edge complete wire harness-good cdi coil headlight/run switch clutch lever w/ perch, ebrake and cables rear master cylinder rear brake lever rear caliper w/ good pads and lines rear rotor , hub thumb throttle assembly overflow bottle stock width axle -some surface rust looks straight swing arm skid stock swingarm good bearings rear carrier w/ good bearings chain and sprockets, sprocket hub- some life left front and rear wheel hubs grab bar- chrome little beat up stock a arms, tie rods, spindles etc - normal wear in paint look to be good and straight frame- paint worn off in spots, straight stock front shocks stock adjustable rear shock front calipers w/ pads and lines front bumper - beat up a little stock steering stem- good straight front wheel hubs and rotors 7/8th aftermarket handlebars- brand unkown black service manual stock heel guards kick start lever, brake and shift levers complete bottom end w/ sidecovers, good tranny needs crank replaced Probably forgetting some stuff. Have complete bike and some extras only thing missing is seat. Not sure on prices for all of it off hand so accepting reasonable offers for now. Please dont lowball though Edited November 19, 2007 by f4istunna Quote
f4istunna Posted November 27, 2007 Author Report Posted November 27, 2007 Willing to trade for some parts also rear 9" yamaha hipers fasst flexx bars steering stabalizer raptor +1 or +2 stem and big bar clamp aftermarket or rebuilt raptor or yfz shocks razr, razr 2 or i razr tires maybe intrerestred in yfz motor for thewhole banshee, or yfz crank for partial trade thanks Quote
ellison445 Posted November 29, 2007 Report Posted November 29, 2007 I got a frame and swinger I will let go for $250 yea i know its goin to alot of $ but..... wut do u want for the frame & swingarm??if u can find out wut the shipping is to area code 11779 Quote
riderofthestorm Posted November 30, 2007 Report Posted November 30, 2007 you said you have a new hot rods crank right? is it stock stroke? do you have the rods? what are you asking for the crank and rods? thanks! Quote
f4istunna Posted November 30, 2007 Author Report Posted November 30, 2007 you said you have a new hot rods crank right? is it stock stroke? do you have the rods? what are you asking for the crank and rods? thanks! Everythings sold Quote
