not really. We have used both. different parts.
brandon
if im not mistaken weisco makes the hotrods and they are marketed under a differant company? ill see if i can dig the info back up i was reading on it.
edit: found it. it was weisco makes the bottom half of the crank and hotrods makes the rods. packaged as a hotrods crank.
either way its still kind the same thing.
Edited by Bansh-eman
weisco crakn and hotrods are the same thing
IMS used to make rods under the Hot Rods name, but Wiseco bought them I believe............. :geek:
Aren't you two working on a formula to promote a special, one of a kind, pirate hooker type of lube called "hot rods"....????
:biggrin: :biggrin:
That motor looks nasty fo sho. You're obviously gonna have to split cases to pull it all apart and clean it, inspect it.
I would take a good, long look at those cases...when the crank comes apart that bad, it can often crack and/or weaken the structural integrity of the cases too...
Food for thought...
:biggrin: :biggrin:
damnit Dave! our investers at Bigboy's IT deptment didnt want anything leaked out until the formula was compplete and EVERY employee was able to test it on a live sheep of thier choice :starwars:
