Lethaface Posted December 1, 2007 Author Report Posted December 1, 2007 did anyone buy your seat yet ?? ifi hadnt redone mine this year i would take it !! thats things one of a kind. Quote
Lethaface Posted December 1, 2007 Author Report Posted December 1, 2007 did anyone buy your seat yet ?? ifi hadnt redone mine this year i would take it !! thats things one of a kind. Nah nobody picked it up on the atv sites. I got it on fleabay right now so maybe somebody will pick it up there. The case saver isn't bad at all. I just mentioned the part that was removed so potential buyers wouldn't end up with something they weren't expecting. Anyways I'm working out a trade on a Tmaxx and the buyer possibly wants the case saver. I will know something for sure by tommorow and maybe we can work something out if you havn't found something else. Thanks, Jeremy Quote
Lethaface Posted December 1, 2007 Author Report Posted December 1, 2007 Whats left 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clampon K&N filters and a Dual Feed Pingel and dave moore super jets. $400 Bowls had a 1" x 1.5" extension added to them for more fuel. They was welded then industrial strenth epoxy was used to insure no leaks. $400 shipped. 14. Billet Case saver. A little bit of material was removed to fit a 16 tooth front sprocket. $25 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also come with a +6 stainless steel brake line. $200 shipped 16. Polished axle $70 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $30 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $110 22. Front hubs. One stud has a small cut/grind into it has a stripped lug nut had to be cut off. It doesn't effect it though and nuts thread on fine with hand. Could be replaced but worked fine. $50 23. Complete break system. Comes with front and rear calipers, master cylinders and MSR front brake Lever. $125 27. Motor mounts and motor mount bolts. This will be upper and lower as well as strut mounts. $20 28. Complete banshee bolt set. Most have been replaced with stainless steel allen head bolts. $40 32. Stock Thumb throttle with polished Cap. Harness still attatched $30 34. KBC gunslinger helmet size XL. very good shape. $110 Quote
01CandyBlue Posted December 1, 2007 Report Posted December 1, 2007 I'll give you 40 shipped on the case saver and the mounts, as long as the mounts are all there, I need the lower ones under the engine and also the front ones where they attatch from the engine to the frame. Quote
Lethaface Posted December 1, 2007 Author Report Posted December 1, 2007 I'll give you 40 shipped on the case saver and the mounts, as long as the mounts are all there, I need the lower ones under the engine and also the front ones where they attatch from the engine to the frame. Yeah i can do that. All the mounts are there. The rear bolt, the bottom strut type and the 2 plates that bolt to the frame and then have the bolt that goes threw them. Paypal addy is [email protected] Thanks, jeremy Quote
01CandyBlue Posted December 1, 2007 Report Posted December 1, 2007 The bolts for the lower strut type are all there. Mine are all missing on this drag frame I got. Thanks Quote
01CandyBlue Posted December 1, 2007 Report Posted December 1, 2007 What do you have in your bolt set? Is it just engine bolts? I need the allen head bolts for the side cases, is that also all the bolts for the plastics and the rest of the bike? Thanks Quote
Lethaface Posted December 1, 2007 Author Report Posted December 1, 2007 The bolt set is pretty much a entire banshee minus a few bolts that need to go out with certain parts like the sterring stem clamp bolts. There is a good bunch of allen head bolts in there though. Quote
Lethaface Posted December 1, 2007 Author Report Posted December 1, 2007 25 shipped for the bolts? Yeah dave i will take $25 shipped for all the bolts. My paypal addy is [email protected] Thanks, Jeremy Quote
Lethaface Posted December 1, 2007 Author Report Posted December 1, 2007 (edited) THIS IS WHAT'S LEFT!! CARBS, SEAT AND HELMET ARE ALSO ON EBAY RIGHT NOW 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clampon K&N filters and a Dual Feed Pingel and dave moore super jets. $400 Bowls had a 1" x 1.5" extension added to them for more fuel. They was welded then industrial strenth epoxy was used to insure no leaks. $400 shipped. 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also come with a +6 stainless steel brake line. $200 shipped 16. Polished axle $70 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $30 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $110 22. Front hubs. One stud has a small cut/grind into it has a stripped lug nut had to be cut off. It doesn't effect it though and nuts thread on fine with hand. Could be replaced but worked fine. $50 28. Complete banshee bolt set. Most have been replaced with stainless steel allen head bolts. $40 34. KBC gunslinger helmet size XL. very good shape. $110 Billet Case saver. Complete break system. Comes with front and rear calipers, master cylinders and MSR front brake Lever, Stock Thumb throttle with polished Cap. Harness still attatched SOLD TO FARMER! Edited December 1, 2007 by Lethaface Quote
Dave I. Posted December 2, 2007 Report Posted December 2, 2007 sent money for bolts....were those carbs converted to alky? Quote
Lethaface Posted December 2, 2007 Author Report Posted December 2, 2007 sent money for bolts....were those carbs converted to alky? Thanks got the money. The carbs are alky carbs. There is more info and a pic on them on ebay if your interested in them. They are at a $300 bid right now. Thanks, jeremy Quote
Lethaface Posted December 2, 2007 Author Report Posted December 2, 2007 THIS IS WHAT'S LEFT!! CARBS, SEAT AND HELMET ARE ALSO ON EBAY RIGHT NOW 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clampon K&N filters and a Dual Feed Pingel and dave moore super jets. $400 Bowls had a 1" x 1.5" extension added to them for more fuel. They was welded then industrial strenth epoxy was used to insure no leaks. $400 shipped. 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also come with a +6 stainless steel brake line. $200 shipped 16. Polished axle $70 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $30 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $110 22. Front hubs. One stud has a small cut/grind into it has a stripped lug nut had to be cut off. It doesn't effect it though and nuts thread on fine with hand. Could be replaced but worked fine. $50 34. KBC gunslinger helmet size XL. very good shape. $110 Quote
