bbcmudtruck Posted November 7, 2007 Report Posted November 7, 2007 I am putting on a new stock swing arm. What all do I need for bearings, seals etc. Who has the kit I need. Also is there some way to gusset or reinforce a stock swinger? Thanks guys Ryan Quote
NYUK Posted November 7, 2007 Report Posted November 7, 2007 pivotworks has the kit for the pivot tube and the carrier. i would recommend drilling and tapping a grease zerk in both. the stock swinger is a big heavy mess of pigeon shit yamaha welds.i wouldnd`t go welding and grinding on it unless you are a professional. i have put many a banshee swinger through massive abuse. the only thing that ever failed was the bearings. Quote
bbcmudtruck Posted November 7, 2007 Author Report Posted November 7, 2007 I appriciate the info nyuk. Where at on the pivot tube does the zerk need to be? Obviously where I can reach it, but is there prefered placement? As far as bending the swinger, I think its just bent where the bearing carier bolts up to it. I didnt want to try and bend back into shape, thinking that it would just happen again. Also, do you have any chain tensioners? Mine are getting a little ugly. Quote
NYUK Posted November 7, 2007 Report Posted November 7, 2007 yes i have a set of chain tensioners.15 shipped. put the zerk where it can easily be greased. Quote
