yama_banshee87 Posted November 7, 2007 Report Posted November 7, 2007 i have 195 main 50 pilot also the needle in the fourth clip2 turns out on the air screw. my mods are fmf fatties, coolhead 20cc domes, 33mm pwk carb, airbox with proflow and k&n no lid. +4 timing. i am running lean on the high i am not sure if i have an air leak. also the temp is about 40 50 degrease out. thanks in advance guys. Quote
Snopczynski Posted November 7, 2007 Report Posted November 7, 2007 What needle? What type of riding? How do you know your running lean? Quote
Banshee0028 Posted November 7, 2007 Report Posted November 7, 2007 Definitely check for leaks: use some carb cleaner around the intakes and such and see if the idle changes. Also like Snop says, did you do a plug chop to tell if its really lean? I would think for your mods and temp, a 195 should be about perfect, if not then maybe a 180-190. But first need to check for leaks, plug chop, etc. Quote
yama_banshee87 Posted November 7, 2007 Author Report Posted November 7, 2007 well i pulled the plug after a run. i only went 5 gears but i didnt rev it all the way out i wanted for about a 5 second count pulled the plug and the porcelin was white and the L shaped thing was light brown. so i figured i was running lean. i just installed this last week. i just used the stock cages w/ just the orings on the intake. was i suppose to use a gasket there also? that is why i think i am running lean. i didn't bog or anything through first three gears. Quote
Snopczynski Posted November 7, 2007 Report Posted November 7, 2007 Always use the reedcage gaskets instead of o-rings if thats what your referring to. Still need to know the needle size? I would think you shouldn't be lean with what you told me so far, but I really need to know what needle is in it. Quote
yama_banshee87 Posted November 8, 2007 Author Report Posted November 8, 2007 i am not sure i did order a dek needle to be on the safe side. let me know what needle i should use Quote
RIPRuck Posted November 8, 2007 Report Posted November 8, 2007 Always use the reedcage gaskets instead of o-rings if thats what your referring to. Still need to know the needle size? I would think you shouldn't be lean with what you told me so far, but I really need to know what needle is in it. We are talking about the trinity 2 into 1 correct? If so than I think he's talking about the o'ring type gasket where the intake mates to the single carb boot. As far as I know a reed cage casket will not fit there. I'm using reed cage gaskets where the intake mates to the reeds and to the cylinders. The intake boot mates with an o'ring which I coat with a thin layer of 1211. Quote
Snopczynski Posted November 8, 2007 Report Posted November 8, 2007 i am not sure i did order a dek needle to be on the safe side. let me know what needle i should use You need to take your needle out and see what size it is and tell me. You probably already have a dek in it. Quote
yama_banshee87 Posted November 8, 2007 Author Report Posted November 8, 2007 You need to take your needle out and see what size it is and tell me. You probably already have a dek in it. all right sounds good. i will do that tomorrow. i have off. also i will install those reed cage gaskets. should i still use the orings with it or just the gaskets. and i will get you a needle size. then hopefully its all good. Quote
Snopczynski Posted November 8, 2007 Report Posted November 8, 2007 Is this an rpm intake with the o-ring grooves cut in the reed cage side of the intake? Quote
chevrolet banshee Posted November 8, 2007 Report Posted November 8, 2007 (edited) Wen i had that single carb i ran a 155 main with needle at the first clip. But i also had the 35mm carb. Edited November 8, 2007 by chevrolet banshee Quote
yama_banshee87 Posted November 9, 2007 Author Report Posted November 9, 2007 Is this an rpm intake with the o-ring grooves cut in the reed cage side of the intake? yes it is. let me know what i should do, snop. Quote
Snopczynski Posted November 9, 2007 Report Posted November 9, 2007 dont use the o-rings on the reedcage side grooves and just use the standard intake gaskets. Make sure they are properly torqued down when you install it. Quote
yama_banshee87 Posted November 9, 2007 Author Report Posted November 9, 2007 dont use the o-rings on the reedcage side grooves and just use the standard intake gaskets. Make sure they are properly torqued down when you install it. cool i will do that i appreciatte the info. what should the tourque spec be on those. Quote
