I have a 01 with t5, comp is good, new reeds, air box cover removed with a k&n air filter. It is flat when it hits wot, it idles great, starts first kick and mid is great. It has 330 mains, is it lean or too rich. thanks for the help robertg
Edited by psu
A few questions first
what elevation are you?
compression good, how good? how 'bout some numbers
extra timing/porting etc.?
I would be willing to bet you are way too big on mains....I have similar setup as you, with big nasty port work, and am only running 300 mains right now...w/stock carbs
what do the plugs tell you?
