ok guys here goes. just put this thing together.. it is a stock stroke 68mm bore cub motor. i put a trued and welded hot rods crank in it.. 33mm pwk's, vforce reeds, 20cc domes with modquad head, and cpi inframes.. i do basically all kinds of riding including drag and trail riding, i do mre trail riding than anything.. well this things makes a ton of power, but dam its hard to handle in the woods. i did the shift pro kit and the modded shift star so shifting is not that bad under power.. my last setup was a stock unported set of cylinders with a noss head 19cc domes, stock carbs, vforce reeds, toomey t5's and timing at +5.. and that was a fast, snappy little motor.. question? if i go back to that setup with the 33mm carbs will it still be as snappy as with the stock carbs? by the way i am new on here and this is my first post
Why dont you just sell the cub cyls and domes.And buy some stock cyls and 4mm Crank and port the cyls for your type of riding.Alot of peepz around me go MUDDING with their cubs but you can tell their not having fun.I almost did the same mistake.If you have a lil more $$ to spend go with the 7mill crank and get your cases trenched.Also did you get a lockup or Overide?But if you have alot of money go with a cheetah powervalve cylinder and head set-up.And 33pwks will be to big for a stock unported motor.Theyll be fine with a stroker and portjob tho.Or just a portjob
get a bad ass port job on stock cylinders , accomodate it with a crankshaft of your $$$ specifications , and hold on... Imo its fun to have the stock cyl's and be competative against SOME cubs. Slap some meth in her.
Chase are you runnung an overide and meth in your bike?Dont know why but Ive alwyas wondered.
man i was hoping that the 33's would work well with a stock cyl setup.. i like a motor that snaps open very quick. the cub is long winded.. the low and mid suck real bad.. then it hits the top like all hell broke loose.. its fun until i hit the woods.. i really want to stay with the stock stroke though. its a new crank.. what kind of portwork would you suggest for an all around trail/play rider?? i dont want to sacrifice any top end power.. i like that strong mid hit also.. i really hate to let ehe 33 carbs go though
Yeah right on the over ride...... My bike has 2 tanks of gas through it in the past year , someone shoot me. At this stage i dont even know if you consider it " running on meth " lol , it doesnt run no matter what... sucks living on the beach as far as the atv scene goes. I am moving out to the boon docks so we shall see.
Lol I havent gone riding in like 4 months.Motors being built and will be ready by Christmas time.Im going to be getting lots of riding time when its done.
Well Im getting a drag port done and 39pwks.And shearer pipes.But thars with a 7mm.And yes I will be riding this thing in trails.If you want a good all around bike with stock stroke than just go with dune-ported cyls.But remember you can sell that crank and get most of your money back and just buy a 4mm and port it and have an awesome trail motor that can hang in the street or track.But If your after all the top-end you can get like I am just go with a drag port.It will be better than the cub but not the best for just trails.
Get Kevin Herr @ http://www.herrjugsracing.com to do your porting, excellent job. Has a great trail port...
my port job has a very very strong mid hit and pulls very hard on top for stock juggs. Traction is my only issue sometimes. Oh yeah and lack of driving skill. Damn missing gears during drag races :ermm:
Edited by RagunCajun
honestly you aint gunna be happy with your top-end on stock cyls when converting from cubs
do you think putting my t5's on the cubs will help with trail riding ( low end and mid pull) i had cpi inframes
Nope dont do it I know dajoejr had t5s on his cub because he wanted to trail ride it and he ended up going to shearers because it wouldnt run right.Ill tell you one thing tho.Call Nate McCoy and tell him you want to port your cub to make it trail friendly and see what he says about that.I know he did it for a guy here in florida and he used it for flattrak racing.With a 2-1 carb setup.1-530-476-2222.If he dont pick up on monday then pm me your number and Ill call him up and give him your number and hell call you.
hey thanx, hard to imagine that you can turn this thing ino a trail motor though.. what pipes couldi run then?? how about i make you a great deal on a cub setup, pistons, dome, stud extenders and all.. the cylinder is polished like chrome too..!!
Nate is a badass builder but it sounds like your more of a weekend warrior and not into some seriouse drag racing. Give Kevin a call at Herrjugsracing. he will set you up a great trail motor and an awsome price and a killer turn around time! i have sent alot of guy to him and i have only heard great responses. not a single bad thing.
you already have a crank so sell your cub, but some fresh stockers and have kevin port them. with the right port job and pipes those 33 pwk will be fine on it. i run 35 pwk's on mine last year with shearers before switching to a cub
