iam measuring for a set of marvinshaw comps
I'm lost homie...it is friday.
Are you measuring center of hole to center of hole without shocks on, with your preferred ride height?
In that case, get 12 1/4.
You can take almost 3/4 of an inch off the bottom of a Marvin Shaw, locknut and collar or just one or the other.
I've removed the nut and collar off all 3 of my shaws, just red loctite it and be good.
Did you check make sure air pressure was the same, etc??
