highroller355 Posted October 26, 2007 Report Posted October 26, 2007 here is a picture of my bike clutch side center to center for shock is 12 and a 1/4 the side for the throttle is 12 even, how bad is this and do i just order 12 and 1/4? Quote
dajogejr Posted October 26, 2007 Report Posted October 26, 2007 Measure it once they're both on... My opinion is I'd run it... Do you have any way to increase the preload, spring pressure, etc? Quote
highroller355 Posted October 26, 2007 Author Report Posted October 26, 2007 Measure it once they're both on...My opinion is I'd run it... Do you have any way to increase the preload, spring pressure, etc? iam measuring for a set of marvinshaw comps Quote
dajogejr Posted October 26, 2007 Report Posted October 26, 2007 iam measuring for a set of marvinshaw comps I'm lost homie...it is friday. Are you measuring center of hole to center of hole without shocks on, with your preferred ride height? In that case, get 12 1/4. You can take almost 3/4 of an inch off the bottom of a Marvin Shaw, locknut and collar or just one or the other. I've removed the nut and collar off all 3 of my shaws, just red loctite it and be good. Did you check make sure air pressure was the same, etc?? Quote
NYUK Posted October 27, 2007 Report Posted October 27, 2007 MARVINS ARE ADJUSTABLE. THE EYES SCREW OUT. Quote
highroller355 Posted October 27, 2007 Author Report Posted October 27, 2007 MARVINS ARE ADJUSTABLE. THE EYES SCREW OUT. perfect ordering 12 1/4 thanks again Quote
