newbie1 Posted October 26, 2007 Report Posted October 26, 2007 I just rebuilt my carbs, and put them on and now the banshee will idle but as soon as I give it gas it just boggs down like it wants to stall???? Im confused. There is no suction in the left carb, but both carbs are getting fuel, and there is suction on the right carb. It did run before the carb rebuild. It would kinda bogg down when I first hit the throttle but then would take off. Could this be the reeds? Quote
Handyman Posted October 26, 2007 Report Posted October 26, 2007 Did you make sure you put the jetting back at the same settings.....like the air screw?? Also make sure the carbs are sync'd Quote
bansheefreak Posted October 26, 2007 Report Posted October 26, 2007 check your choke tube that goes between the 2 carbs.. Quote
