ok i just came back from glamis and didnt get to ride my shee i couldnt get it to start. the night before we left to glamis i installed a ricky stator timing plate and put it at +4, i checked plugs and theres no spark please help!
go pick up a feeler guage, i cant remember what its suppose to be set at but set it to the right settings and then kick her over, make sure your key switch and kill switch is on as well.
you just loosen the screws and gap it .
i think i read its roughly the thiknes of a matchbook cover.... im not sure though i believe its like .18mm or sumthn...
if u do a search you should find the proper gap. :thumbsup:
yup its about a match book....
how do you adjust the coil its held by screws and theres not much room for it to move
you dont need to move it much the gap is between .15 and .20 if your not over or under your good. and make sure you gap it with the part sticking out the center of your flywheel , the round part of the wheel. if not you brake shit.
Edited by xXBlessedWithDeathXx
