I have no idea on whats up.....i've cleened the carbs..one of the intake boots was cracked so i replaced that..i got v-vorce 3's and one guy told me that somtimes they will come apart and wont let enough airflow in...another guy told me that it could be somthing to do with my electronics....when i give it gas it cuts out,then u wil feel the powerband starting to come a little bit then it will cut out again....any pointers???
Yessa, sounds like electrics from here. One thing to try is removing your air filter for a test. Note any change. Sounds like you need to look at the electrics to start with. pickup coil, plug wires and caps. Is it smoking bad? when did it start?
Brandon
Brandon
nope not smokin bad....after a few races it started doin it so i parked it......i removed my airfilter doesnt make much diffrence but i bought the dual k&N kit just in case.......
tors or parking brake maybe. choke crossover tube connected?
yeah the tubes connecting.....what do you mean parking brake???
try your spark plug caps. i`m on my 3rd one in about 3 months. my shee runs like a monster then all a sudden when i open it up it bogs but it will run like a champ if its not open. once i changed the caps it was a monster again. replace the caps.
