I removed the tors system from my banshee and tapped the carbs and removed the bur from inside and thought everything was good . The slides work perfect when it is not running but stick about where it starts to come on the pipe every time . There is no way you can make either slide stick not running no matter how slow you move the thumb throttle they work perfect.
I wish I had not removed the tors now because I really screwed up a ride up north . I rode about 45 miles keeping it in third gear most of the time and off the pipe. .
Any thoughts on a reason for this to happen ??
The removal kit was Vito's and the motor was just rebuilt +.030, fatty pipes, vforce 3 reeds, 21 cc domes
Thanks for any help
Jim
