Well I got half the intake done, and I started hogging out 1 of the cages so far. That reed cage porting is tedious work. Just got to bolt on the other cage, hog out the intake and match the cage now. The new intake outlets are 3.0mm bigger on each side from when I started. Took this pic with the cell phone.
Edited by Snopczynski
what are you going to do with the intake? that's the most importaant aspect of the 2-1 setup as you have the "Y" in the intake and must seperate the airflow as efficiently as possible. The old Graydon does this pretty well.
Basically I opened up the cages and made the intake runners larger all the way through. Then I match ported the cages, and the rubber boot inlet. When I did the intake runners I reshaped them so when the fuel and air comes in they are diverted straighter down with less angle like the graydon intakes do. Where the intake met the cages was way off, the intakewould overlap the cages in several spots, and on the inside edge of the cages stuck out. I smoothed it all out and took out all the cnc marks that were in it also.
nice. i see what the pic is now, it was hard to tell w/o paying attention like i did the first time and your explanation helps. sounds like a fun project and i'm sure the outcome will be worth it. take a pic for us looking in from where the carb is, looking at the Y, if possible. looks good tho. trying to remember how the vforces line up with the inside of the single carb intake.... what your doing has gotta help.
Edited by sredish
I'd bet the Vforces are lined up about like the stockers... maybe a little better but I wouldn't imagine much.
Yeah, true! I am gonna have a motor over here and apart next week. It has vforce 2's in it. I can check it out.
Here is the front and back of the intake. Its done, just need to sharpen the edges of the porting on the manifold off. Only thing left to do now is match the cages.
