peterlocal22 Posted October 6, 2007 Report Posted October 6, 2007 (edited) ok guys, i sent my clutch cover out to cali to get it polished. i took off the big water pump cover but kept the smaller one that covers the impeller on. when it came back i put in a new billet impeller. i then installed the new gasket for the clutch cover and the polished clutch cover. i torqued all the bolts to specification. my next step was to torque the bolts for the small water pump cover. i then relized i probably shoul have oiled the bearings that are attached to the impeller. should i take the clutch cover off and oil the bearings or should i be ok?? thanks Edited October 6, 2007 by peterlocal22 Quote
xXBlessedWithDeathXx Posted October 6, 2007 Report Posted October 6, 2007 well, i wouldnt have oiled it but if you do it wont hurt. better safe then sorry. Quote
LiftdT4R Posted October 7, 2007 Report Posted October 7, 2007 I'd say fuck it, I never knew you had to oil them, I can't tell you how many times I've put mine back together and never even knew about it. If the bearing is a used one it should be oiled enough allready anyway. Quote
