Hilarious Posted December 30, 2007 Report Posted December 30, 2007 whay carbs do you have ?? 35 pwks :smile: Quote
kawiking Posted January 8, 2008 Author Report Posted January 8, 2008 do you all run shaved flywheels ?? Quote
kawiking Posted January 8, 2008 Author Report Posted January 8, 2008 really ??? i like how much faster it revs up !!! Quote
theshee Posted January 8, 2008 Report Posted January 8, 2008 I heard you will loose a little low end and a little torque. Not sure if its true, but i need all the low end i can get in the climbs. Quote
BigRed350x Posted January 8, 2008 Report Posted January 8, 2008 Plus... with the lightened flywheel you will loose too much when you have to let off the throttle to miss a tree or something, then you lose your rpm's and die off too fast. The heavier flywheel helps hold your engine's momentum up so when you get back on the throttle you're not going to just bog out. (or at least that's what you hope for) Quote
kawiking Posted January 15, 2008 Author Report Posted January 15, 2008 i like having my flywheel shaved, but ive also seen acouple come apart. my 300 pound buddy said a shaved flywheels not made for a bigboy. lol... Quote
NitroTate Posted January 15, 2008 Report Posted January 15, 2008 I had a lightened flywheel and it actually sheered off in a perfect circle all the way around the center shaft. In other words it was like if you were to have taken a cutting torch and cut right around the shaft and pulled it out of the center. Weird... wish I had a pic of it Quote
kawiking Posted January 15, 2008 Author Report Posted January 15, 2008 thats what my buddies did, all the way are the edge. Quote
nayr742003 Posted January 16, 2008 Report Posted January 16, 2008 It actually depends on what kind of hills they are if they are sand i agree with alot of the other guys but if it is dirt like here in pa i can climb alot around here and mostly everything i try and my bike has just a 2+ swing arm and dura blue axel and a bost bottel on it the motor has ben board over 30 over and thats it it all is up to the rider not the bike try some normal sized hills and go from there you know your bike the best so go from there and try it out. Quote
kawiking Posted January 16, 2008 Author Report Posted January 16, 2008 do you think the boost bottle helped your bike out ?? :biggrin: Quote
nayr742003 Posted January 22, 2008 Report Posted January 22, 2008 no the boost bottel didnt help me it was a waste of money Quote
kawiking Posted January 25, 2008 Author Report Posted January 25, 2008 :yelrotflmao: ahhh..... i love the old boost bottle trick !!! Quote
