Generally rod play will cause excessive wear or fail but not really kill skirts. Do you have enough piston support and port chamfer? Axial end play on rod is .009-.029in if that helps. That would be measured with a feeler between thrust washer and rod.
Brandon
Thanks guys this information has been helpful
