hey, im am looking at getting some new front suspension for my banshee to make it a kick ass MXer and have some questions on the e bay kits. it comes with elka SSD Piggyback front shocks with compression/ride Height adjust,+2 laeger arms and brake lines for $1700 canadain. do i have to get the shocks set up or do they come to my weight and rideing??? and how hard are they to install?? is there hole reaming???new bushings????? and how hard to set ride hight and the shock?arm alinement????i would love of some help on this
i think thay build them for you and it seems that it wood be real ez to install
but i don't know anting about elka shocks so ajusting them my guess is as good as yours :confused:
the shocks will come valved and sprung for your weight and riding style (trails, mx ect) u tell them that when u order them.. they are very easy to install, 1 bolt on top, 1 bolt on bottom..as far as the leagers a arms go, im not sure if you have to reem your spindles, but for the prices they charge, i would sure hope not, the arms should come complete with new bushings installed in them usually, as far as seeting ride height i have no idea, but im sure it comes with instructions and if you passed 8th grade, u should be able to do it, getting your shit all lined up how u want it will take a little bit, small adjustments, ride around,see how u like it, maybe adjust more, its not hard by any means though, just takes a little patience when you are messing with the tierods and stuff, suspension work isnt rocket science though you will have no problem with it
Where in Canada do you live . I go to a shop and they hooked me up real good . I got the burgard 3+1+ and Elkas with most of the goods . Elka builds the shocks for you . your wight, riding style , leve of riding and what size a arms your going with if its a 2+ or a 3+ . install is is pretty good too 3 bolts for the a arms on each side and 2 bolts for the shocks on each side .
  • 4 weeks later...
What is your opinion on the Burgard long travel kit? Well made? Tough? Easy to install?
