202banshee Posted September 24, 2007 Report Posted September 24, 2007 When I pull the clutch in all the way it still grabs some. Is there a way to adjust it without opening the side case ?? The lever has no freeplay so I dont think adjusting it there would help, maybe at bottom. Also if I have to open the case can I just take the side panel off that has the phillips head screws?? Or do I have to take the whole side off like online manual said???? Clutches are new the guy I bought it from had them done at a shop. But that is the same shop that couldnt get it to fire up. So maybe they couldnt adjust the clutch correctly ????? :down: :down: Quote
peak-j Posted September 24, 2007 Report Posted September 24, 2007 Yep, you have to pull the whole cover off. Quote
