I know I need a manual but dont have one yet. Downloaded the one on here and it helped a bunch along with alot of help from you all.
Ok I have fac carbs with tors caps.I have 2 large screws on the caps (which I believe are the idle screws) To small brass ones that are almost flush (left side of each carb) But i also have two large ones that are brass in color with nuts to lock. No matter how I adjust these I get no change. Originally I thought they were idle screws. But you guys tell me no, I have got my idle down to a respectable point with a combo of adjusting the screws up top and backing off the cables and synching the carbs better. BUT what are the side screws for THANKS HELP :blink: Also remember I just bought this from a guy that done a great bit of screw turning on carb trying to get it to run.
Large screws on top of TORS boxes are idles. Small brass screws on left of carbs towards filter side are air bleed screws for fine idle-1/8 throttle adjustment. Larger screws on side with lock nuts sounds like idle screws for TORS eliminator kit. Someone probably took the kit off and put the TORS back on just for you. Might shoot a pic but if that is the case, back the side screws most of the way out and tighten and never touch them again unless you put a TORS eliminator kit back on.
Brandon
Brandon
You know what that had crossed my mind but I thought who would be that stupid LOL Should i worry about them sealing to prevent an air leak ???
Also with my idle screws all the way out should there by any gap at all between slide bottoms and carbs. I couldnt get my idle down till I backed off the cables and that let the slides drop down some but they would probably go more.
You need to just back off the side idle screws to where they do not contact the slides and tighten them. No need to remove and seal the holes. Use the top idle screws. If your cable is tight, it should not be. You must have some slack at the throttle lever for things to work right. If your TORS system is unplugged, you can use the side idle screws but it could present carb balancing problems.
Brandon
Brandon
I think I got it pretty good,, running fine right now. Its in garage in back of my pickup and dont have any help to unload it LOL So I havent done a blast down the street yet. But as soon as I do I will know more. Also wondering how the cold start is gonna be now that carb is set ALOT better. You guys helped me alot any more help or tips would be appreciated THANKS
