Bansheeman1121 Posted September 18, 2007 Report Share Posted September 18, 2007 Ok the right carb dumps gas everywhere, ontop of that the right plug is always soaked black while the left is perfect, when in nuetral it will rev up but start breakin up horrible tords wot, and backfire horrible like ciompletly cut out and black smoke comes out when it backfires, im freakin stuped i had the carbs apart cleaned the hell out of em and its still dumpin fuel, ink already what the hell this problem is plz help Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted September 19, 2007 Report Share Posted September 19, 2007 Either your float in the right carb is set too high, or the needle, and seat above the float is dirty, or worn out. If you have a Clymer's manual, it will tell you how to set the float height, and/or take out the needle, and seat for cleaning, or replacement. There are several threads on here, about adjusting the float height, and cleaning carbs, so try the search function for those. If the float height is correct, and cleaning the needle, and seat doesn't change anything, then you will have to replace the needle, and seat. If the needle, and seat needs replaced, it would be a good idea to change them in both carbs. Quote Link to comment Share on other sites More sharing options...
BansheeKid15 Posted September 19, 2007 Report Share Posted September 19, 2007 if fuel is dumping out, that means that your floats are stuck. it could cause all the problems that you listed. Having the floats set at the wrong height will also have an effect similar to the first one. What are you jetted at? Quote Link to comment Share on other sites More sharing options...
Bansheeman1121 Posted September 19, 2007 Author Report Share Posted September 19, 2007 Thanx for the replies im jetted at 330 mains,vetos needles on the leanest clip and 30 pilots the bike always ran fine, then i got water in the gas so i cleaned the carbs and must of bent a float or somthin in the proccess im gonna check the floats today and ill let ya no how it goes thanx again Quote Link to comment Share on other sites More sharing options...
