I just got the head milled and when I put it back together and started it up anti-freeze was leaking around half of the head bolts. I was wondering if the gasket has a top and a bottom or is it just probably put on wrong. It is a new gasket and I torqued the bolts down to 18 ft. lbs. If any one has any sugestions please let me know.
When I did mine (Milled head also) I used a gasket sealer. Copper spray adhesive for gaskets. Cant remember brand. Then I torqued slowly and made several passes only tightening a little each time until torq reached.
I don trun stock heads anymore, but I think I remember there being "UP" stamped into the stock headgaskets. Did you torque it down with a torque wrench?
you can also try some permatex on the studs.....thats what most do with the aftermarket heads.
Dan
Dan
modquad has new washers they send out with their kiss that have rubber in them -no more leaks dont knoe if it will work with a stoch head but they work great on aftermarket headt to stop the leaks
Dan
Sounds like it may have not been milled true. Id spend the money and get a aftermarket head. Im pretty sure the stock head gasket is top and bottom though. Thats probably the problem.
i thought the torque is 20 not 18??
Did you torque in increments of 5?
Yep. 20lbs. A $25 Clymer is the best mod for a Shee.
