im selling the engine because i have decided to get a little crazy and put a crotchrocket engine in the shee. so i have no more use for my current set up....any of it actually...so its all for sale, and id like to keep it all together
first off this engine was just recently rebuilt with less then 3 hours on it, where we took it to the local strip to break it in. its bored .20 over with wiseco pistons....the head is milled .8 so compression is right around 150-160 i checked it before it was even started and it was 154 so it should be more now. it has a drag racing port job with boost Ports drilled in...this was done by twin marine (a local speed shop in miami)...the bottom was also rebuilt, it has a 2005 crank in it thats been trued and welded. the gears and clutch are both fine and look good when we had it apart.
this also comes with complete wire harnes, clutch cable, trottle cable+ stock carbs and intakes with reeds, 2 cdi boxs, fmf pipes with toomy tips completly painted black (i hate the fmf silencers so i mocked these upand they look good).... stock air box with k&n air filter
this has everything to start running minus the radiator which im keeping just in case i want to use it in the swap
im looking for around 1000 for the entire set up.
miami, fl
will ship
  • 2 weeks later...
these are the only pictures i have of the engine....its out of the bike now so i could get more per request if needed...thanks
how much for the girl who's head is cut off in the picture.....??? i am looking for a girl like that ... so she cant talk back :evil:
7862736666 have fun lmao
still for sale bump
Ok, Can you give me a price shiped to north miami, and if not too much trouble north florida. Im out of the states right now but i need the engine asap. so i will send it to a friend. So ill wait on the price.
Thank you.
Jamie
Good deal BUMP!
Hope I find a deal from a member when I need my other Banshee engine and electrical.
