chiwape Posted September 16, 2007 Report Share Posted September 16, 2007 I just purchased a set of ASV levers F3 twin pack with the clutch and brake lever. I began to put on the brake lever but it doesnt fit the front master cylinder. Is there some modification i have to do or did i get the wrong asv levers??? need some help seen plenty of banshees on here with them... Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted September 16, 2007 Report Share Posted September 16, 2007 you got the wrong lever... i did the same thing... contact ASV they will tell you which part number is the correct one... the right one bolts stright on the master... Quote Link to comment Share on other sites More sharing options...
