chiwape Posted September 16, 2007 Report Posted September 16, 2007 I just purchased a set of ASV levers F3 twin pack with the clutch and brake lever. I began to put on the brake lever but it doesnt fit the front master cylinder. Is there some modification i have to do or did i get the wrong asv levers??? need some help seen plenty of banshees on here with them... Quote
Bansh-eman Posted September 16, 2007 Report Posted September 16, 2007 you got the wrong lever... i did the same thing... contact ASV they will tell you which part number is the correct one... the right one bolts stright on the master... Quote
