04titanse Posted September 14, 2007 Report Share Posted September 14, 2007 i bought my 2000 shee stock. only i though Tors was removed because there are moose carb caps and a new throttle cable and the big units over the carbs arer not there but..... today i did the e-brake block off kit and when i pulled the cable out the bike wouldnt rev at all then i manually pushed the e-brake handle thing and then the bike would run fine. basically because i pulled the cable out it was sensing the brake was on and not letting it rev. how is this possible if tors is removed. I cut the wires and now it runs fine but i am curious why this happend. Quote Link to comment Share on other sites More sharing options...
Hilarious Posted September 14, 2007 Report Share Posted September 14, 2007 i bought my 2000 shee stock. only i though Tors was removed because there are moose carb caps and a new throttle cable and the big units over the carbs arer not there but..... today i did the e-brake block off kit and when i pulled the cable out the bike wouldnt rev at all then i manually pushed the e-brake handle thing and then the bike would run fine. basically because i pulled the cable out it was sensing the brake was on and not letting it rev. how is this possible if tors is removed. I cut the wires and now it runs fine but i am curious why this happend. All that shit is hooked together into the electrical system. Look under the gas tank on the left side. There should be a small box, bolted to the frame. You should also remove that. :beer: Quote Link to comment Share on other sites More sharing options...
xXBlessedWithDeathXx Posted September 14, 2007 Report Share Posted September 14, 2007 what he said. Quote Link to comment Share on other sites More sharing options...
04titanse Posted September 14, 2007 Author Report Share Posted September 14, 2007 alright cool thanks guys! Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted September 14, 2007 Report Share Posted September 14, 2007 the bike wont idle if the black box on the frame is still plugged in the bike wont rev if the parking break sensor is still plugged in Quote Link to comment Share on other sites More sharing options...
