Fireroad Express Posted September 16, 2007 Report Posted September 16, 2007 NO NO No hold it wide open, kill it then take out the plug then look through the plug hole with a light and a lil magnifying glass and you can tell if it is lean by how big the wet spot of gas on the piston...the smaller the wet spot the leaner it is. well that s how you fine fine tune the thing checking "piston wash" is actually a real good way to check your air/fuel mixture on a two stroke engine where you can see directly down the plug hole. you are checking the size of the carbon deposit on the top of the piston. the bigger the deposit the richer the the mixture. Quote
fishwater Posted September 18, 2007 Report Posted September 18, 2007 Exactly on snowmobiles you look down the plug hole to see piston wash but on a bike I would just get it warmed up & do the WOT test. I wouldn't waste any time chopping a plug. Quote
phreak Posted September 20, 2007 Report Posted September 20, 2007 checking "piston wash" is actually a real good way to check your air/fuel mixture on a two stroke engine where you can see directly down the plug hole. you are checking the size of the carbon deposit on the top of the piston. the bigger the deposit the richer the the mixture.i think you have that backwards. Quote
dajogejr Posted September 20, 2007 Report Posted September 20, 2007 i think you have that backwards. Try that with a methanol bike....there should be little to no coloring, no deposits... Methanol blows out the exhaust whatever it doesn't burn... Quote
fishwater Posted September 20, 2007 Report Posted September 20, 2007 The thought is that if it is too rich it will wash the piston & leave it clean looking. When tuning sleds I always made sure the piston wash was minimal & the burn pattern looked good. You get a feel for it based on conditions & the way the sled runs in addition to the piston wash. Quote
Snopczynski Posted September 21, 2007 Report Posted September 21, 2007 That center one is what my stock pistons looked like when I tore mine apart to do my port job last winter. Quote
