slowpokebanshee Posted September 8, 2007 Report Posted September 8, 2007 I just picked up some used 34 mm flatslides-but no throtte cable was included, which one do I need, and where can I get one? and which air filters? I have t-5 pipes Quote
Ducman Posted September 10, 2007 Report Posted September 10, 2007 This is where I got my last cable (below), they have one for a twist too. The springs on the TM 34mm Mikuni are stiff as F**K. You will probably want to cut a couple coils if you keep the thumb throttle. I cut mine so that the spring wants to hold the carb top about 1/2" above the carb body when it is unfastened and I still have plenty of spring to keep the slide down, still way stiffer than stock. I had a twist throttle when I first got the 34mm Mikunis and that was a lot more comfortable but I didn't like a twist in the sand whoops. vitos 34mm Mikuni and stock thumb throttle Quote
