04titanse Posted September 5, 2007 Report Share Posted September 5, 2007 hey everyone i have a bunch or parts coming and i can't wait to get them all installed. But i am not sure how to jet with all this stuff. Here is a list of all the parts i am putting on!!!! Right now the bike is 100% stock: w/ tors eliminator kit K&N pro flow intake no lid w/ outerwears toomey T5 pipe set w/ silencers ricky stator adj timing plate carbon fiber replacement stock reeds dynojet jet kit anyone have a clue were i should start with jetting. I have no idea were to start! Thanks for any help, i cant wait to feel the power after these mods!!! hopefully the shee will be able to keep up with my raptor 700 now thanks Quote Link to comment Share on other sites More sharing options...
okbeast Posted September 5, 2007 Report Share Posted September 5, 2007 What's your elevation and normal temps. Quote Link to comment Share on other sites More sharing options...
OnlyA2Stroke Posted September 5, 2007 Report Share Posted September 5, 2007 (edited) hey everyone i have a bunch or parts coming and i can't wait to get them all installed. But i am not sure how to jet with all this stuff. Here is a list of all the parts i am putting on!!!! Right now the bike is 100% stock: w/ tors eliminator kit K&N pro flow intake no lid w/ outerwears toomey T5 pipe set w/ silencers ricky stator adj timing plate carbon fiber replacement stock reeds dynojet jet kit anyone have a clue were i should start with jetting. I have no idea were to start! Thanks for any help, i cant wait to feel the power after these mods!!! hopefully the shee will be able to keep up with my raptor 700 now thanks You are going in the right direction with those mods. Now just do the lightened flywheel, ebrake block off, & cool head(with 21cc or 20cc domes depending on your compression) or a milled head. Then you are pretty much set for a fast bike. I was staying in front of my 06 yfz450 (stock) in a grass field with those mods. But anyways, to answer your question you could be anywhere from a 280-310 mains depending on your elevation and temp. I have a lot of humidity in Missouri so mine was a bit on the rich side. I would leave the stock 25 pilots in and run them around 1-1.5 turns out. Now with your CF replacement reeds.... I run VF3's and my bike was runnin terrible between shifts in trails with the Dynojet/Toomey needle on 4th clip(from blunt end). So I put in on the 3rd and Shee rips! Let me know what your temps are and I could get you close, but all bikes are different so plug chops are a must even though they suck wastin all them plugs. Edited September 5, 2007 by OnlyA2Stroke Quote Link to comment Share on other sites More sharing options...
04titanse Posted September 6, 2007 Author Report Share Posted September 6, 2007 temperatures are around 70-80 degrees here in Connecticut and avg elevation is 500 ft. so assume those are my regular riding temps. Thanks for the input guys! the more advice the better i am trying to learn all above the banshee and how to make power and tune them! Quote Link to comment Share on other sites More sharing options...
okbeast Posted September 6, 2007 Report Share Posted September 6, 2007 I'd recommend starting somewhere closer to a 330 just in case. I'd tell you what mine were exactly but they were drilled so I'm not sure at all. Just buy a bunch and try one and go from there. Quote Link to comment Share on other sites More sharing options...
04titanse Posted September 6, 2007 Author Report Share Posted September 6, 2007 i have the dynojet stage 3 jet kit coming.... should that have all that i need to get the jetting right or will i need more jets and stuff?? thanks for all the help guys! Quote Link to comment Share on other sites More sharing options...
okbeast Posted September 6, 2007 Report Share Posted September 6, 2007 Dunno what comes with the kit? BTW jet kits may be the biggest waste of money since the boost bottle...IMO Quote Link to comment Share on other sites More sharing options...
Ducman Posted September 7, 2007 Report Share Posted September 7, 2007 300-310 main, needle 3rd or 4th clip from the blunt end, 27.5 pilot air screw 1.5 turns out. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted September 7, 2007 Report Share Posted September 7, 2007 300-310 main, needle 3rd or 4th clip from the blunt end, 27.5 pilot air screw 1.5 turns out. bingo! this is the setup for sea level to 1500. if its not right on you will be very close go with the needle on the 3rd first. Quote Link to comment Share on other sites More sharing options...
04titanse Posted September 7, 2007 Author Report Share Posted September 7, 2007 i really appreciate all the help once everything comes in the mail i will get started! Quote Link to comment Share on other sites More sharing options...
