Alrighty, last week i put in the shift pro shift kit. Works like a charm. I also installed the cascade innovations shift star. the install went smooth.
Now the bike tends to be hard to shift from 1-2 2-3 3-4, mostly 2-3 i believe. Mostly when im slipping the clutch and holding it WOT and shifting up. If i let off, clutch then shift properly, it's fine.
I took the clutch basket off so i can see the problem in person. I reached over and worked the shift with my hand while watching the shift star work. The bearing on the shift pro kit is getting stuck on the shift star's point. Anybody have this problem and if so how to fix it.
I took the kit out, the shift shaft out and the star out. Everything seems to be fine. I made damn sure i screwed the star in good and tight. I will test it out tomarrow.
I think if i didnt fix the problem today, i will take the shift star out and grind down the points a little bit. Maybe even a little angel on one side.
Check the shift shaft adjustment to make sure the pins on the shift star are centered when its in gear.
Edited by MDS2106
