I have a 02 banshee with fmf fatty pipes. The quad has 05 carbs on it with the throttle positioning sensors remove and new carb caps installed. The quad starts and runs ok but loads up on he bottom nad has to be babied in gear with the throtle to get going as it loads up very bad. In midrange it hacks and caughs and top end is better but it wont let me give it full throtle or it will bog and lag. It has been bored 30 over and piped and some idget jetted it . The bike has less than a hour on new build pistons,rings . The air box has a modified lid but is otherwise stock. When i pull the plugs they are soaking wet and fouled. any help guys?????
