BAMA07 Posted July 27, 2007 Report Posted July 27, 2007 OK, so i put my new toomey pipes on my stock banshee, and vforce reeds. Rejetted and all went from stock 200 jets to 280 jets left the pin on the 3rd notch and the only way i can get it to run semi right is by having the pilots turned 6 1/2 turns out with no airbox lid now i know this cant be right. Any ideas what i need to change to get it going if i move the notch on the needle to the richer side would this help? plz help before i have to take it to the yamaha shop and they will rape me with the price to tune it. Quote
dajogejr Posted July 27, 2007 Report Posted July 27, 2007 Something else is wrong. After 3 turns or so...you're passed the adjustment range. Check to make sure the choke tube is in place, and make sure the carb slides are in the right carbs...the half moon-shaped cutaway is facing the airbox side. Check sync on the slides while you're at it.... Quote
Snopczynski Posted July 27, 2007 Report Posted July 27, 2007 Something else is wrong. After 3 turns or so...you're passed the adjustment range. Check to make sure the choke tube is in place, and make sure the carb slides are in the right carbs...the half moon-shaped cutaway is facing the airbox side. Check sync on the slides while you're at it.... My votes on the cross over tube. Quote
halfrack Posted July 31, 2007 Report Posted July 31, 2007 I had a similar problem and it was the carb slides in the wrong carb. Try switching them. When you do fix your problem Im curious to know what it is. Quote
