Alright, the run down. 05 LE, FMF Pipes and boost bottle, K&N Air filter with pro flo and rejetted to 190 and thats about it for power gain. I have been told cold head and crank and timming but I am clueless and how to do it. It seems every time I try to do something I forget to tighten something back down and spend hours figuring out what I did wrong. Is there anywhere I can take my shee to get some performance work done. I have some V-Force reeds on the way but where and what do I do next. I am in central Ohio and if anyone has any ideas it would be great. Thanks!
well first get a cylmers manual.. then you can do most of the bolts on yourself.. but i would suggest a noss head with smaller domes,lighten fylwheel,timing plate.. you should be able to do all this yourself if you get a manual.. as for crank no need to get a diff crank till its time to rebiuld and only if you wanna upgrade to say a 4mm stroker...
Im in northern OH and i cant say i know of any good shops for banshees in the area, the closest would be in sounthern michigan probably because of Silver Lake
buy a manual and a set of torque wrenches. Save a ton of money
good point. If you really dohave 190s then just a rejet will give you your power boost.
im pretty sure FMF gives you 260s with their pipes
SORRY, was a typo, 290 mains, sorry about that. Thanks for the info though, where can I pick up a manuel ?
