i wanted to no why some people extended there frames and not there swing arms is it cause u loose tractionjava script:bbc_pop()
you streach the front becouse it helps keep more waight on the back tires so it gets better bite but if you dont have anuff motor to long will hurt you
Dont extend your frame that much if you are going to dune it though. Also, dont do something like get an extended frame or have yours mounted and a run a stock swingarm. You pry know that already but ya never know lol
going out the back helps from wheeling..going out the front is for launching,,weight and motor placement also helps with power and weight distrabution.
